Mowing kubota mid mower rck60-24b
   / kubota mid mower rck60-24b #1
judesson
I have a gear oil leak on my mower, I have found one seal below the gearbox pulley toward the blade, But is their a oil seal at the gearbox between it and the pulley ? Any help would be appreciated. thanks
   / kubota mid mower rck60-24b #2
I just rebuilt my RCK60B_22BX mmm. If you go to tractorsmart.com, you can down load the parts manual for your mower deck, tractor, ect. With the parts manual you can also order parts from there...
If the 24b is like the 22bx then there is an oil seal which seats in the gear box on the main shaft prior to the pulley. I would imagine that this is the case, but the parts manual will show you what is there for sure...
Good luck
2020 Kubota SVL 75-2 Skid Steer (A51573)
2020 Kubota SVL...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
2020 Peterbilt 520 T/A Cab and Chassis Truck (A51692)
2020 Peterbilt 520...
Miller Wildcat 350-D Welder (A51691)
Miller Wildcat...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
