Kubota mid mount for hilly terrain
   / Kubota mid mount for hilly terrain #1
dpandolfo
I have 10 acres of hilly terrain to maintain. I have 6 acres of weeds and briars, 1 acre of finish mowing, and a 1000' road to keep snow off and keep it maintained with gravel. I would like a front loader for general work around property.
First question is whether a B series will handle the job. Or, whether I should jump in to an L series. Please help me with my safety concern of tipping over on side and down hills. This is my first real tractor.
I am considering an L3010 GST and a B8200 4 x 4.
Thank you.
   / Kubota mid mount for hilly terrain #2
You should post this in purchasing, not safety.
That said, how steep are your slopes? most tractors are only good for 15 degrees (which will pucker you up tight on a regular tractor). There are a couple of wide stance tractors, or I would suggest either a Power-Trac or a Antonio Carraro if you have the bucks...
   / Kubota mid mount for hilly terrain #3
If you can get a truck up it,you should have no problems getting about any 4wd regular type tractor up it,even if you gotta use 4wd in the truck.
Go up and down not sideways,bellymower,not much experience with one but unless you got it hung up[high centered] it should even be better?,mowers down low in center of tractor.
Always put it in 4wd when on a steep hill,or wet grassed hill.
If it don't feel right,don't do it,[might take you awhile but somethings start feel better the more you use it,experience].
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
(4) 6 LUG GMC TIRES & WHEELS (A51248)
(4) 6 LUG GMC...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
New/Unused 2025 CFG MX20R Mini Excavator (A51573)
New/Unused 2025...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53472)
2012 JOHN DEERE...
