kubota m9540dt
/ kubota m9540dt #1
Screnshaw
kubota 9540dt
I purchased a low hour used kubota 9540dt last month out of state. After getting it home and running it I realized it is not going in 1st or 2nd gear in either H/L . There has been a couple of times I have gotten it in second gear and it works great and then will go back to not going back into it. I have never gotten it to go into 1st gear. Any thoughts on what I need to do?
/ kubota m9540dt #2
Which transmission does it have ?
Cab or open station ?
E/S
/ kubota m9540dt #3
when i brought my new M8540 (HD 12 sp) home it also wouldn't go into 1st. I finally pulled the boot over the gear shifter: a small "linkage/bracket" was not tightened up right. a quick fix that has worked 350 hrs later. u might start there.
btw the 85/9540 is about the best machinery overall i've ever operated.
(former machinist & teacher: that's probably more liability than anything else) good luck
/ kubota m9540dt
It was the linkage. I tightened it several rounds and it is working great right now. Thhanks for the help. Now the pto light is staying on even when the pto is not engaged. I have to now figure out how to get the plastic cover off at the lever to adjust it.
/ kubota m9540dt #5
Get a illustrated parts manual, it really helps me.
E/S
UNUSED ATSPOWER 40 GALLON AIR COMPRESSOR (A64281)
UNUSED ATSPOWER 40...
2013 Volvo BL70B 4x4 Extendahoe Loader Backhoe (A61572)
2013 Volvo BL70B...
JMR MINI TRAILER MOVER (A61572)
JMR MINI TRAILER...
JOHN DEERE 220 CENTER FOLD DISC HARROW (A63291)
JOHN DEERE 220...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
2019 VOLVO VNL TANDEM AXLE SLEEPER (A59911)
2019 VOLVO VNL...
