Tractor Sizing Kubota M9540 vs M105S
   / Kubota M9540 vs M105S #1
sutherland
Bergman, Arkansas
Kubota, David Brown, Kubota
I can purchase a 2007 Kubota M9540 w/ROP with approximately 650 hours and in excellent condition and triple remotes for about the same price as a 2006 Kubota M105S w/ROP tractor with about 925 hours and dual remotes and in very good condition. Both have hydraulic shuttle. Which is the better tractor?
   / Kubota M9540 vs M105S #2
the q you need to ask yourself is do i need the extra hp.if yes then go with the 105.if i had the money id prolly get the 105 but thats just me.
   / Kubota M9540 vs M105S #3
It really depends what your intended use is. The 9540 is lighter, less HP and a little more manuverable. It would be better suited for mowing, spraying, tight quarters, and easier to trailer. The M105 is made for heavier applications where it's HP and added weight with give it an advantage. Things like moving 2 round bales at a time, ground engaging work, etc... Both are great machines.
2005 Ford F650 Fire Truck (A49461)
2005 Ford F650...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
2014 VOLVO VHD (A50854)
2014 VOLVO VHD...
HUNTER SYSTEM 700 TIRE BALANCER (A50854)
HUNTER SYSTEM 700...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A49461)
Miller and Smith...
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
