Oil & Fuel kubota M7500DT replacing inner front pto shaft seal
   / kubota M7500DT replacing inner front pto shaft seal #1
kubotaky
nsw
kubota m7500dt
Kubota M7500DT - need to replace the inner front PTO shaft seal. Have split the tractor, but wondering if I need to take the transmission out as well to remove or can I access it still in the tractor ?
   / kubota M7500DT replacing inner front pto shaft seal #2
I just now read your March 5 post about the pto clutch. Looking at the attached parts diagram from the factory website, seal #24 is accessible by removing #23 with the trans still assembled and attached to the rear housings of the tractor. But replacing the inner seal #30 is more involved. A M7500 workshop manual would show how far apart the trans needs to be to replace #30. Maybe someone will chime in who has the WSM or actual experience with this transmission.
Before doing a major disassembly of the tractor I'd be tempted to pack some greased cotton string into the annular space between the pto shaft and the inside of shaft #1. Trans oil isn't under pressure and it might be simple to stop most of the leak. Good luck. Dick B
  • M7500 1st and pto shafts.pdf
2011 INTERNATIONAL PROSTAR PREMIUM DAY CAB ROAD TR (A51243)
2011 INTERNATIONAL...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
Maverick 3250 Excavator Hammer (A50774)
Maverick 3250...
UNUSED JMR MINI SKID STEER 40" GRAPPLE (A51244)
UNUSED JMR MINI...
5' X 20' 3/8" THICK STEEL PLATE (4) PIECES (A51244)
5' X 20' 3/8"...
2018 CAT 320GC Excavator (A47384)
2018 CAT 320GC...
