Kubota M7060HDC A/C Belt Tensioner
   / Kubota M7060HDC A/C Belt Tensioner #1
jomch
Quitman, Ga
Kubota
Replaced A/C belt tensioner bolt, lock nut and two nuts at the end of the tensioner bolt, as the parts diagram shows. When tensioning the belt, instructions were to turn the tensioner bolt counterclockwise, which I did, but the two nuts at the end of the tensioner bolt just unscrew and fell of. What am I doing wrong? Thasnk you!
   / Kubota M7060HDC A/C Belt Tensioner #2
The tensioner on my M9000 just keeps the belt in alignment and not much more.
   / Kubota M7060HDC A/C Belt Tensioner #3
The AC tensioner on our M100X, LX3310 all turn counterclockwise to tighten the belt. The tension on the LX 3310 has to be tightened about a turn and a half every 50 hrs. Too small a belt , for the loads, in my opinion. For right hand threads, point your thumb in the direction you want movement. Your finger will curl in the direction of rotation, use left hand for left hand threads.
1995 Ford L8000 Grain Truck GARAGE KEPT (A55301)
1995 Ford L8000...
2022 Polaris Ranger Utility Cart (A53421)
2022 Polaris...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
