Kubota M7060 broke- Need help!
   / Kubota M7060 broke- Need help! #1
houser52
Cherryville, NC
Kubota M7060HD, Kubota L3600
My M7060 is an open station with a 4 speed transmission with high/low range. (8 speed)
The problem is that a bolt came out of the linkage that connects the high/low range shifter to the linkage to the transmission. There are 2 bolts on that connection, 1 is gone and the other is loose. The way it is now I can't shift to high range.
The location of the linkage, with the missing bolt, is down under the transmission shifter. I can see it from above but can't get to it from the top. I also can't get to it from underneath.
What is the easiest way to get to that part without removing the whole console?
   / Kubota M7060 broke- Need help! #2
i don’t know about your tractor, but on my MF1540, to access the linkages, i have to remove the metal platform that the seat is bolted to. Is very simple - just four bolts and the whole seat lifts off. Might be a similar set up on your Kubota.
   / Kubota M7060 broke- Need help! #3
your 7060 gear shift linkages may be different than my M8540. when i bought it new, same problem as yours, cannot shift into low range. i pulled the rubber gearshift boot and i believe also removed shifter cover, an easy access. one short linkage arm was loose, so i tightened connecting bolt & was an instant fix. 12 yrs later works perfectly
maybe you can display a pic of a top view of your setup. this should be an easy fix for you unless there are lost parts.
go to your dealer for a schematic & get the lost parts. the bolts on mine are small, requiring some dexterity good luck
Thanks for the replies.
Got it fixed. I had to remove part of the console and loader joystick. luckily the console was not 1 piece so I only had to remove part of it. That made the linkage easily accessible. Once that was done the missing bolt was easily replaced using Loctite on both bolts. Not a hard job at all. The hardest part was driving to the hardware to get the replacement bolt.
1992 Peterbilt 377 Sleeper Cab (A52748)
1992 Peterbilt 377...
2018 Nissan Titan Pickup Truck, VIN # 1N6AA1E57JN515039 (A51572)
2018 Nissan Titan...
2015 Chevrolet Equinox SUV (A50324)
2015 Chevrolet...
2018 Infiniti Q50S Sedan (A50324)
2018 Infiniti Q50S...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
