Kubota M7040SUDH adding winch to front
   / Kubota M7040SUDH adding winch to front #1
waggy5
New York
Kubota M7040 & B2320
hi, i would like to add a 9000-12000 lbs. DC winch to the front of my Kubota M7040. any advice? also, i need to run power to the rear of the M7040 to run my dump trailer's hydraulics. any advice where to get power from? thanks a million!
   / Kubota M7040SUDH adding winch to front #2
I would a build a mount that attaches to the front where the grill guard is for the winch.
For powering your dump trailer I would run the cables to the back of the tractor and use a quick connector like this so you can plug and uplug for the trailer easily.
Superwinch 2236 Quick Connect : Amazon.com : Automotive
   / Kubota M7040SUDH adding winch to front #3
That's a good question. Not sure where to go to get the power. Might be best to go straight to the battery. The winch will come with two heavy battery type cables with eyelet ends that can be bolted to the tractor battery cable ends where they fasten to the battery. The ground wire could be fastened to the frame of the tractor if it is easier to do. But the power cable needs to go as directly to the battery as possible. I don't like to use the starter solenoid connection because you risk causing corrosion at that location and possible starting problems. Then the winch will have a hand held, usually 12ft long control cable that plugs into the winch.
As for the dump trailer, again, you need to get power as close to the battery as possible and run very heavy wire to the rear of the tractor. You might want to research the trailer system to find the amp draw needed. That would guide you to the wire size and fuse size needed. I would avoid trying to get power from the tractor wiring system at the rear. I don't think there is anything back there wired or fused heavy enough to power your lift motor. My M9540 has an electrical plug at the rear for trailer use but I'm sure the circuitry isn't heavy enough to power a hydraulic lift motor.
New Holland 853 Round Baler (A49251)
New Holland 853...
2005 Ford F-450 IMT 2020 J370729 Crane Service Truck (A48081)
2005 Ford F-450...
JMR Stump Bucket (A49251)
JMR Stump Bucket...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
2013 Ford Explorer SUV (A48082)
2013 Ford Explorer...
2018 16FT UNITED UXT-716TA52-8.5 ENCLOSED TRAILER (A45678)
2018 16FT UNITED...
