Mowing Kubota m7040 Rotary cutter
   / Kubota m7040 Rotary cutter #1
nato674
Allgomera NSW
Kubota m7040
Looking into getting a Rotary cutter for my 7040 and I'm interested to see how large of a cut others have been getting without flogging the tractor too much. Im running it through around 3to 5 foot deep grass on average.
   / Kubota m7040 Rotary cutter #2
That's some tall grass! You might want to stay around the width of the machine. Is this thick green (wet) grass or more of a dry climate sparse & dry grass? Sound's like you need to make hay out of it.
   / Kubota m7040 Rotary cutter #3
Your tractor will handle a 10 and 12 foot cutter with ease. I would look at Bush Hog, Woods, and Land Pride for parts support. Look at a semi mount for the heavier units. You can handle a 3 point unit if you have adequate front weight as a ballast. I've run a 10 foot Howse and it was a good unit.
Im in Australia so not sure we have those brands but 10 ft sounds good. I borrowed the neighbours 6ft and it cruised around in mid range 4th no problems except for the dense stuff then it was 3rd.
   / Kubota m7040 Rotary cutter #5
I've pulled a 15' bat wing with a similar JD with no problems, just not through 3'-5' tall grass.:laughing:
A friend just bought a giant single spindle woods, the "heaviest" model they build and run's it on his 7040 without power issues although he said it's a little too heavy.
   / Kubota m7040 Rotary cutter #6
I use a 8 foot 3696 by land pride on my M7040. I would have to slow down in my thickest weeds. They were as tall as my head sitting on the tractor. But for average mowing I would say that a ten foot would be the best for that size grass. I thought the 'roos nibbled it all down to the nub?
Haha the roos don't get a chance around here :) Grows like wildfire.
   / Kubota m7040 Rotary cutter #8
six foot will be all it wants in 3 to 5 foot tall grass
   / Kubota m7040 Rotary cutter #9
agree w the others that your machine could handle a large batwing for normal growth. but given the height of your pasture, i'd stick with a compromise of 8' 3 point hitch twin spindle type that would cover your tractor's width. i like having the lift option for obvious reasons.
@ 2000 lbs, my 8' rhino is a perfect match for my m8540
   / Kubota m7040 Rotary cutter #10
Bush Hog 3008 works nice behind a M7040, haven't tried the 15 foot batwing that the guy had.
David from jax
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2013 JLG 8042 TELEHANDLER (A50854)
2013 JLG 8042...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A50854)
2021 ALLMAND BROS...
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
2018 LAYMOR SM450-ST SWEEPER (A51242)
2018 LAYMOR...
