Kubota M6800 Steering Controller Leaking
   / Kubota M6800 Steering Controller Leaking #1
CAH2873
I have a Kubota M6800 that has a leak coming from the steering controller. I have looked online and to purchase a new controller it cost around $1,100.00. There is an aftermarket one that goes for arouns $600.00. I currently can not get the steering wheel off in order to remove it.
My question are:
If I am able to get this off, can a seal kit be purchased for this or do i have to buy the whole unit?
If I am able to get the steering wheel off, is there a trick to get the steering shaft removed from the steering controller box?
Thanks in Advance,
CAH2873
   / Kubota M6800 Steering Controller Leaking #2
I have the same issue. Tractor steering still works but the controller area is leaking oil. Has anyone attempted to just purchase a seal kit and repaired it. Or just the oil seal ? Help ?
   / Kubota M6800 Steering Controller Leaking #3
I've been told no repair parts available. I have to purchase a new unit.
   / Kubota M6800 Steering Controller Leaking #4
Far as I know, there is no rebuild kit available, just exchange. Getting the wheel off is removing the hut an d striking the underside of the wheel with a dead blow mallet or using a gear puller. It's splined.
   / Kubota M6800 Steering Controller Leaking #5
   / Kubota M6800 Steering Controller Leaking #6
It appears from viewing Kubota M6800 parts catalog a seal kit(3A999-11980 @ $87.49) is in stock at Messicks.
@ Tx Jim. Your avatar info made me smile. A new member with over 9000 posts. I read the story so you don't need to explain. I just saw the humor in it. Merry Christmas!
   / Kubota M6800 Steering Controller Leaking #7
Being able to utilize my old handle after not being able to log in took a few months & several personal messages to rectify. The fact that my avatar shows me as a ""new member with 9119 messages"" is of little concern to me.
MERRY CHRISTMAS
   / Kubota M6800 Steering Controller Leaking #8
I had this issue.
Before thinking about steering controller repair or replacement check the hose tightness at the controller end first. There are 4 of them. In my case leakage concerned the hose, which comes from the hydraulic pump. It was too loose. To get access you need to remove steering wheel (special tool required or DIY one) and to remove dashboard and 2 plastic covers. Then tighten the hose. At this moment nothing to do with a steering wheel shaft.
All that - if the design of steering system of m9000 (mine) and your m6800 are the same.
P.s.: my description applied to a ROPS tractor.
   / Kubota M6800 Steering Controller Leaking #9
Good luck on rebuilding it. The internal tolerances are extremely close. On the OS unit the controller mounts below the steering wheel. On a cab model it mounts over top the valve cover with a shaft and universal joint. If mine went, I'd just replace it. Never had that issue however.
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
Kohler Generator (A50322)
Kohler Generator...
John Deere 1560 No Till Drill (A52349)
John Deere 1560 No...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
Takeuchi TL140 (A47384)
Takeuchi TL140...
