Kubota M59 pops out of gear?
   / Kubota M59 pops out of gear? #1
lwm
Bronze Member
Los Gatos, CA
Kubota B21 TLB, 3 spool T&T, 6 foot blade, box scraper, post hole digger. Kubota M59 TLB, EA 8 foot scraper, 8 foot Gannon box scraper, WR Long OBG 1. Kubota KX161-3S Excavator, 12, 16, 24" buckets, 30" flail, hydraulic thumb. Very tole
Hi all,
I've had a M59 pop out of gear on me twice. Once in high, once in medium. Both times going down a hill.
After the first time I'm very careful about being in gear, when I shift I check the lever and make sure it is in
place and I go forwards and backwards to see if it pops out.
I've got some sketchy work in front of me, steep hillsides, need to move 20 yards of dirt. I can't have it pop
out again, I don't have the runway to stop it. So I'm looking for insight, is this an M59 thing? I've got a B21
and it has a much more secure shift pattern, it's never popped out.
Thanks for any insight.
--lm
   / Kubota M59 pops out of gear? #2
Suggest you re-post this in the Kubota Owning/Operating sub-forum. There are a number of M59 owners on TBN, they may be more likely to see this over there. Good luck resolving your issue. I've done similar work, and just the thought of having the tractor pop out of gear makes my neck hairs stand on end!
   / Kubota M59 pops out of gear? #3
I have had a similar issue with my Kioti DK45. It provides an unwanted jolt of adrenaline to have the tractor suddenly take off downhill at speed!!
When this happened eight years ago, it was a shift fork problem. I'm hopeful that isn't the issue now.
So far, I have had good luck by going a gear or two lower on the steepest parts. I don't like how this slows the pace of my work, but, so far, it seems to have kept the tractor from popping out of gear.
Good luck.
   / Kubota M59 pops out of gear? #5
You have hills in PEI?
Yep. Sadly, I happen to live in about the hilliest part, too. Out of 250 acres, I have almost zero flat land. Nearly all my cleared land is above 10% slope and some parts of the pastures and hay fields are in the 20% to 30% slope range; the wooded areas are still wooded mostly because they are even steeper.
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A51222)
2022 INTERNATIONAL...
LOT LOCATIONS (A51222)
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
GORMAN RUPP 4 TRANSFER PUMP (A50854)
GORMAN RUPP 4...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA (A50854)
2018 FREIGHTLINER...
