Tires Kubota M5700 4WD Front Wheel Lug Nut Torque Value
   / Kubota M5700 4WD Front Wheel Lug Nut Torque Value #1
ccbrd
While installing new front tires (9.5 x 22) I discovered several stretched wheel studs.
This is the first time the wheels/tires have been removed.
I installed three (3) new front wheel studs/lugnuts (Kubota OEM) M14 x 1.5 thread.
My owners manual calls for 124-145 foot pounds torque value.
I'm getting excessive stud/thread stretching at 135-140 foot pounds.
I set the torque at 125 foot pounds.
I use a good quality "click-style" torque wrench and "do-not" use an impact wrench to install the lug nuts.
Has anyone had this problem?
What torque value do you use for this application?
Thanks for the help/info.
CB
   / Kubota M5700 4WD Front Wheel Lug Nut Torque Value #2
L3700 specifications call for 160 ft. lbs rear and 100 ft. lbs front. This is also on a 4WD unit. 135-145 sounds high to me. I don't however argue with the manual? How are you checking to discover stud stretching? Are you saying the threads are actually being deformed? Something doesn't sound right....
   / Kubota M5700 4WD Front Wheel Lug Nut Torque Value #3
My OP manual - for front/rear wheels on 4WD. 192-224 ft. lbs for the inner ring of nuts & 180 ft. lbs for the outer ring of nuts. This is the spec for both front/rear wheels. I, also, wonder how you are determining that the studs are stretched. If they are truly stretched - I'd be contacting my Kubota dealer with this concern. Agreed - something isn't sounding just right................
Another thought - you say this is the first time the wheels have been removed - - I guess it is possible that they were overtightened when it came from the factory - never heard of this, but its possible.
I inspected the studs/threads before reinstalling the wheels/new tires.
I ran a thread chaser on the studs.
I was surprised to find thread stretching (about 3 threads +/-) at the base of the stud (nearest to the axle hub) on several.
Yes, the threads are deformed/stretched.
I replaced three (3) of twelve (12) studs.
When installing/torquing the lugnuts the newly installed studs (3) stretched the threads similar to the original studs.
The factory/dealer may have overtightened the lugs originally.
I removed and replaced the three (3) newly installed studs and torqued to 125# with no problem.
After resetting all lugs to 125# they have remained tight after working the tractor.
The local Kubota dealer replaced the three (3) studs and is submitting them for warranty.
I thought the specified torque (124-145 foot pounds) sounded high but went with the manual.
There are "no markings" on the studs regarding "grade" which makes it difficult to consult a torque chart for guidance...
Thanks for your help/info.
CB
   / Kubota M5700 4WD Front Wheel Lug Nut Torque Value #5
Another data point -
My M4700/M5400 manual specs 191 to 224.2 ft lbs for front inner and 123.9 to 144.6 for front outer nuts.
Interesting, my manual specifies front inner & outer at 124-145 foot pounds.
When I torqued the lugs I "worked-up" starting at 120#.
At 135-140# I noticed stretching.
I should've stopped at 125# (the low end of the spec)!
What torque value have you used for your M4700?
Thanks for your help.
CB
2019 MACK PINNACLE (A48992)
2019 MACK PINNACLE...
Pallet of (8) 8 Lug Misc Wheels (A48837)
Pallet of (8) 8...
2022 CATERPILLAR 349 EXCAVATOR (A50458)
2022 CATERPILLAR...
2016 Volkswagen Passat S Sedan (A48082)
2016 Volkswagen...
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A49461)
2013 GMC Sierra...
Kopalift 2,000lbs Electric Walkie Stacker Forklift (A49346)
Kopalift 2,000lbs...
