Hi folks,
Unfortunately my local Kubota sales team is a lot more eager to sell what they can get than what I will need, so I want to get some external opinions.
I just moved on to a >150 acre property in the northern rockies and I need to do *everything*. To start with I need to do general construction as well as property development including road development, bridge construction, building foundations, etc. After we're a little more comfortable, we're looking at a wide variety of hobby farm agriculture. The property is currently irrigated for livestock pasture and that will continue but we likely want to move from direct grazing to a small hay operation (~30 acres of hay).
Based on my research the m4-71 is about the lowest HP that is reasonable to use with a baler. It's a much big tractor than the L6060 and I worry that it might be overkill in the long run. The L6060 also has the 3-range HST, which seems like it would be more convenient for the non-agricultural use cases. Anyone have any opinions or illuminating follow up questions that might help me sort this out? I'm a buy once / cry once kind of guy, but I'm also open to the possibility that I should get a much smaller "starter" tractor as a gateway into the right purchase.
Cheers!
Cheers!
