banjerpicker
- Joined
- Jan 14, 2006
- Messages
- 36
I have discovered I have a short in my wiring harness underneat the dash on the left side. I have voltage to the starter and can slap on the left side of the dash and the key will allow the tractor to start.(holding the key in pre heat mode and banging on the left side will allow the panel to light up in preheat mode, then start...otherwise nothing...dead...battery good, lights come on very bright
How do I get to the wiring harness under the dash. Do I have to remove the steering wheel the pull the cover out of the way. I obviously see the outside bolts that will have to be removed.
Thanks Larry
Thanks Larry
