Kubota M series dash removal
   / Kubota M series dash removal #1
Gomer pyle
Murfreesboro, TN
John Deere 5090E
How do I remove the dash from a 8540 with ROPS? I need to lube or replace the shift cable.
   / Kubota M series dash removal #2
can't help you but please post what you find out. had to replace the hyd shuttle cable on same model. it is an involved job. they really should have an accessible oil lube nipple as routene maintenance given the cable's frequent use. regards
On a ROPS model, it seems fairly simple. Just not sure how to remove the dash and don’t want to break it.
I’m hoping some spray lube will fix it
   / Kubota M series dash removal #4
have rops as well. fuel tank removal is what dealer did. it's a long cable, lubing it from dash interior is a start. take a pic with dash removed to view access to that cable. good luck
   / Kubota M series dash removal #5
On both my M9's the entire instrument panel comes out with 4 screws but you have the remove the steering wheel first. No fuel tank issues, I have twin low mount saddle tanks.
   / Kubota M series dash removal #6
Both my range shift and the main box shift are all via mechanical linkages. No cables at all. Only my PTO is cable operated. but then mine are antiques.
   / Kubota M series dash removal #7
shifters on mine are similar, all mechanical linkage. but assuming you have hyd shuttle, that is cable operated i believe on mine at least. that's the OP's situation. will be interested in the outcome
Mine is sync shuttle, it has a cable
   / Kubota M series dash removal #10
Mine is as well and like I stated earlier you can access the cable by removing the wheel and fender on an open station unit, that allows you unfettered access to the cable and where it hooks to the hydraulic valve on the side of the gear case and you can also adjust the lockup pressure there but you will need a liquid filled pressure gage and fitting. I borrowed that from my dealer when I checked it. On my open station the shuttle lever goes down the column a ways and the cable hooks to it. I was having issues with it not retaining a neutral position so I applied some P Blaster to it followed by some light motor oil and that has appeared to work. If it don't go to the neutral position on mine, it won't crank.
2001 Dodge Ram Wagon Passenger Van (A51692)
2001 Dodge Ram...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
John Deere 6125M (A50120)
John Deere 6125M...
2016 John Deere 6155M (A50120)
2016 John Deere...
