Kubota M 4900
   / Kubota M 4900 #1
Chip's Kubota
M 4900
I've had this tractor sense new and this is the first problem I had. There is a clicking noise in the front left wheel. I lifted the wheel off the ground and spun it but no noise but when I move the tire side to side there is a little movement. After inspecting the T rod end is where the move ment is coming from, with out weight on the front end no clicking noise. I checked all lug nuts and wheel nuts and they are tight. i'm going to change the T rod, is there anything else I should check while I have the tire off. Thanks in advance .
JOHN DEERE TS 4X2 GATOR (A51406)
JOHN DEERE TS 4X2...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
Informational Lot - Financing (A55218)
Informational Lot...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
