Kubota LA650A FEL Question
   / Kubota LA650A FEL Question #1
Goodtimze
Eastern CT
Kubota L3450
I have a Kubota L3450 with a LA650A FEL. I was wondering if anyone has any info on it. It came on my tractor used and no paperwork. I am looking mainly for information on how the quick release works. There are four rods stored on the frame of the loader that I don't know what they are used for.
   / Kubota LA650A FEL Question #2
The two flat bars with the foot welded on one end are attached to the threaded blocks that are welded on the bucket. To do this use the 2 J style bolts that you have to remove from the round crossbar on the front of the tractor (be sure to clean out the threads in the block on the bucket before fastening the stands ).
Once the stands are secure remove the wedge locks on each side of the loader uprights. Once removed use the hyds. to raise the lift arms up out of the saddle, when these raise up a square hole will be visible, insert the other two supports in these hole to help balance the loader.
Can't remember for sure you may have to back the tractor up enough so that the supports will clear rear loader supports.
Once all supports are in place and clear of loader supports again use the hyds. to set the loader on the ground, then turn off the tractor release hyd. pressure on the hoses by working loader control valve, then unplug your hoses.
Before uncoupling hoses be sure to mark them, if they are not color coded, this will make it easier to reconnect in the right location.
Hope this will help. :)
1043 (A50459)
1043 (A50459)
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A51039)
2024 BCL...
vergenes (A50657)
vergenes (A50657)
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2006 International 9400i (A51039)
2006 International...
