Kubota LA211 control valve with a BX2750D snowblower
   / Kubota LA211 control valve with a BX2750D snowblower #1
mikebx220
Kubota BX2200
I took the post off of my LA211 front end loader and I'm using the valve to control my BX2750D snowblower. This year I'm hooking up a hydraulic motor to my chute to rotate it. I'm using the ports of the valve that control the dumping of my LA211 front end loader bucket. When I push the lever of the valve to the right the chute rotates clockwise. When I pull the lever to the left nothing happens. I then switched the hoses at the hydraulic motor and the chute rotates counter-clockwise but not both ways. That told me that the hydraulic motor is reversible like the website said where I purchased it. Is that correct? Does anyone know where I'm going wrong and why the valve isn't turning the chute in both directions?
   / Kubota LA211 control valve with a BX2750D snowblower #2
Move your lever to hard right and see if it moves then. You have 3 different points with the lever.
   / Kubota LA211 control valve with a BX2750D snowblower #3
The curling function on that lever has regen function for curling while lowering the bucket. Also there is float function on the main boom cylinders
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2007 FELLA SM350 3 PT DISC MOWER (A53472)
2007 FELLA SM350 3...
KUBOTA KX080-4 S2 EXCAVATOR (A51246)
KUBOTA KX080-4 S2...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
New/Unused CFG Industrial MX15 RX Mini Excavator (A51573)
New/Unused CFG...
