KUBOTA L6060 COLD START
/ KUBOTA L6060 COLD START #1
TIVI
Kubota L-6060
Whenever I start my L6060 in below freezing temperatures, it immediately rev's up to full RPM and will stay there until the machine warms up. It's stored in an unheated garage, but the block heater is plugged.
Any suggestions?
/ KUBOTA L6060 COLD START #2
That does not sound good. I have no idea what is causing that.
/ KUBOTA L6060 COLD START #3
I've owned two L6060's and have not experienced this with either one. If the tractor is new or still under warranty, I'd call the dealer.
/ KUBOTA L6060 COLD START #4
Whether it's under warranty or not, I'd check in with the dealer. The tractor is probably computer controlled, that is the computer sets the throttle, not you. One of the sensors may be defective or the computer itself could have issues. It is not good to go full throttle on a cold engine.
/ KUBOTA L6060 COLD START #5
Any suggestions?
Lets take care of the obvious first, you do have the throttle/rpm lever all the way down correct?
Is it trying to do a regen?
I ran an electronic search through the user manual just to be sure and I dont see anything that would kick the rpm up automatically just because its cold.
/ KUBOTA L6060 COLD START #7
I’m thinking that it might be related to the block heater? It should only be used for a couple of hours prior to starting the tractor. If it’s always plugged in there’s the risk of internal condensation at the colder edges of the engine. Maybe there’s a linkage that freezes up due to moisture in subzero temperatures? Keep us posted.
/ KUBOTA L6060 COLD START #9
There is a method to enter a menu on the L60 series that may display error codes. I've never tried it, but I pasted the procedure below.
I have never had my L4060 act like that, with or without the block heater. I got this procedure likely from a TBN user.
1. Press Display mode button and hold
2. Turn Key to On
3. Several modes will appear
4. Press Display Mode until "D" is highlighted
5. Press and hold display mode for more than 2 seconds
6. "Want to clear codes? Hold button for 3s more" Will appear
7. Press and hold Display Mode for 3secs
8."Cleared" will appear
9. Turn key to "off"
Then your computer should be reset. Mode "A" is a diagnostic mode and gives information about your temps, rpms and volts going to switches on the unit, kind of neat to look at and could be helpful in the future.
/ KUBOTA L6060 COLD START #10
Electronic controls or mechanical, they all start at full throttle or the fuel rack advanced.
Ok….but shouldn’t it adjust to a reduced setting at startup?
/ KUBOTA L6060 COLD START #12
Never seen that behavior on my L4060 either. Unless of course I left the throttle up or bumped the it or something. I have a block heater on mine as well. Only use the block heater when it's below 20 or so.
You never want to hammer the throttle until it's got a chance to build oil pressure. I'm not a big believer in long warms, but give it a little bit of time to gets some heat if it's below 40 or so. No matter what, at least give it a chance to build proper oil pressure. Wish the Lxx60s has an oil pressure gauge on them.
Standby generators tend to go straight to operating RPM. But that's hard on them & they prioritize function over longevity. They are usually on block & coolant heater, possibly pre-lube systems too, at least on the bigger ones.
A lot of food for thought!
Thanks guys for all of thee ideas. I'll let you know how it goes.
Mower King Brush Cutter (A53317)
Mower King Brush...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
PALLET OF(3) CABINETS & (5)BOXES OF CARPET SQUARES (A60432)
PALLET OF(3)...
More info coming soon! (A56859)
More info coming...
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
