Kubota L48 stating problem
   / Kubota L48 stating problem #1
Projex
Canton,Ct
Kubota L48
I've been using this tractor to grade a section of my property for lawn. I've been switching between the loader and the backhoe a lot and when I spin the seat around the female end of the seatbelt which is attached to the seat hits the pto lever causing the machine to stall if my weight isn't on the seat, every time this happens I just put the pto lever back into the off position and the machine starts fine, well yesterday it happened again and now the tractor won't start, it lights up and when I turn the key it just clicks like there is a safety switch not activated, does anyone have any experience with this problem and if so how'd u get it to start? Also I think the cable for the pto lever is bad because when I pull the lever into the off position the cable does nothing and I have to get under the machine and manually put the arm in the off position... Any help would be greatly appreciated
Thanks, Jeff
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A50854)
2013 XLR...
2017-2023 Ford Super Duty 4x4 Pickup Truck Bed (A49461)
2017-2023 Ford...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
(INOPERABLE) MAROOKA (A50854)
(INOPERABLE)...
