Kubota L48 PTO/RPM Clutch Problem
   / Kubota L48 PTO/RPM Clutch Problem #1
ChompinBrush
I've got an L48 that has a broken clutch lever to engage the PTO. The lever seems to work fine (that is it pulls the cable) but the spring loaded PTO clutch won't move. I can get it to engage/disengage if I get under the tractor and move the lever by hand. It is getting tougher and tougher to engage and disengage it. Now I have to use a wood block and tap it with the a hammer. It has gotten so bad that now I think it is effecting the PTO speed. I can't get the tractor RPM above about 1500 even when I give it full throttle. The engine seems to rev up but the RPM guage won't go above 1500 RPM. Not nearly fast enough to get to the 540 RPM PTO speed I need to run most equipment.
Anybody else have this problem? Any ideas on how to fix it?
Thanks!!
2017 Kubota SVL95-2S Compact Track Loader Skid Steer (A50322)
2017 Kubota...
Grundfos Centrifugal Pump (A50121)
Grundfos...
Kubota Salt-Spreader (A52384)
Kubota...
2002 John Deere 5220 (A50120)
2002 John Deere...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
