Kubota L48 parts question for FEL
   / Kubota L48 parts question for FEL #1
Jason280
Ga
Kubota L4330
Ok, I managed to break one of the hinge pins for the loader on my L48. The loader assembly is the TL1150 SG, but i cannot locate an online source for the hinge pin. Is this something that will have to be sourced through the dealer? The pin that has broken is the one at the end of the hydraulic cylinder on the right hand side looking down from the seat, which pivots the bucket to dump. Thanks!
   / Kubota L48 parts question for FEL #2
I would guess that there are no aftermarket sources for those pins. A dealer would be the logical source.
Some of the pins / bushings are pressed in so that may be a factor as well. The dealership has an exploded diagram of the FEL so you can see all of the parts necessary to do the repair.
Just be thankful it wasn't the cylinder - those things are outrageously expensive.
   / Kubota L48 parts question for FEL #3
hello gwdixon,
You may be able to find the manual at kubotabooks.com
that's where i found my manuals for my l2500 and la350 loader.
I just changed pins on my loader cost 34.00 each and they don't come with grease fittings or cotter pins.
hope this helps Carl
I'm going to check with the dealer in the morning, as I don't believe they can be sourced anywhere else.
Rhino FS15 Flex-Wing Rotary Cutter - 15 Ft Heavy-Duty Brush Hog for Pasture and Roadside Mowing (A51039)
Rhino FS15...
2013 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2013 INTERNATIONAL...
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
2004 Ford F250 (A50515)
2004 Ford F250...
2009 KENWORTH T800 (A50854)
2009 KENWORTH T800...
HUSKY 135 PSI AIR COMPRESSOR (A50854)
HUSKY 135 PSI AIR...
