Backhoe Kubota L48 boom wont lift
   / Kubota L48 boom wont lift #1
Jason Heaster
Kubota L48
I have a Kubota L48, the boom will not raise at all, no fluid leakage anywhere, all other functions are working fine, any help or ideas would be appreciated.
   / Kubota L48 boom wont lift #2
Does your backhoe have quick disconnects? If it does Disconnect and reconnect.
Make sure they are connected all the way
   / Kubota L48 boom wont lift #3
Also. Does your L48 have a switch to route hydraulic pressure from the BH to the 3 point hitch? If so, make sure it's in BH mode.
Tried the quick disconnects.. It is in backhoe mode, I am totally lost here, I bet its probably something simple. Thanks for all the help so far
   / Kubota L48 boom wont lift #5
Is the lock still on?
Does the crowd and bucket & swing work?
Front Loader?
   / Kubota L48 boom wont lift #6
Actually re read your post wont raise.... lock wont do that...
Does the lever feel like it is moving the spool?
Will it apply down pressure?
the lever is moving the spool, the down pressure is normal, everything else works great. Any other ideas?
49" X 79" EXPANDED METAL RAMP GATE (A51247)
49" X 79" EXPANDED...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
CATALOG UPDATES LOT NUMBER 5 (A53084)
CATALOG UPDATES...
New/Unused AGT YSRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
