Kubota L4740 GST
   / Kubota L4740 GST #1
jon1matt74
Sparta
John Deere
I found a kubota L4740GST 4wd with loader and 255 hrs for $17K. Is this a good tractor and is this a good price?
Thank You
   / Kubota L4740 GST #2
Certainly started as a good tractor,check maintenance records to see if fluid changes have been done.
That is low hours for the year.General condition,leaks,paint ect.?What tires and loader(they offered two I believe).
   / Kubota L4740 GST #4
This is a Kubota heavy-chassis 'Grand L' tractor, the Lexus of tractors. It it is in good shape $17,000 is a very good price.
This model has less complex Tier III emission controls, rather than more complex Tier IV emission controls.
Grand Ls do not linger in the resale market.
L4740 in T-B-N Archive:Google
   / Kubota L4740 GST #5
Just make sure the transmission fluid gets changed, every 300-400 hours and use Super UDT. GST is an automated 12 speed gear transmission with a forward reverse wet shuttle clutch, do not need to use the foot clutch for any shifting.
If treated well that is a very good tractor and can pull all day without any of the concerns one would have with a hydro overheating.
Check and see if the front drive shaft seal is leaking or has been replaced, only real problem I have heard on that series.
David
   / Kubota L4740 GST #6
2013 Freightliner M2 106 Altec DC47T Insulated Derrick Digger Truck (A50323)
2013 Freightliner...
2012 WABASH 53FT DRY VAN TRAILER (A52141)
2012 WABASH 53FT...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2015 Kubota MX5200F 55HP Loader Utility Tractor (A51691)
2015 Kubota...
20305 (A51694)
20305 (A51694)
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
