Kubota L4400DT or L4330DT
   / Kubota L4400DT or L4330DT #1
dmltrac
1655 difference in pricing. The l4400 did not have quick detach bucket available per dealer.
ANyone compare these two?
I have not ruled our mahindra 4410 but these kubotas look good. I did rule out Kioti dk45 which I was considering. Too much noise/vibration.
It seems the kubota resale is much better than the kioti or mahindra.
mike
   / Kubota L4400DT or L4330DT #2
What kind of prices were you given on these two machines? The reason I ask is that I am looking at those two as well.
   / Kubota L4400DT or L4330DT #3
$1655 isn't much of a difference. For that money the L4330DT seems like the better deal. I'm assuming the transmission quoted on the 4330 was the basic 8F/8R FST with shuttle shift...if not it's an even better deal.
What you won't get on the L4400 that you WILL get on the L4330 is:
1) about 400lbs. more weight....which is good
2) shuttle shift...no need to stop to reverse direction
3) 9.4GPM flow for the implement hydraulic pump, vs. about 7.4...better for skid steer attachments
4) Skid Steer QA option for the loader
5) Mid PTO is available as an option
6) Telescopic lower link ends on 3pt hitch...nice
7) Tilt steering wheel
8) about 300lbs. more lift capacity at 3 pt. hitch...no big deal
9) More gravitas when posting here on TBN /forums/images/graemlins/grin.gif...Grand L owners immediately join the TBN inner circle.
Going the other way, the L4400 has a couple of more HP than the L4330. Other than HP, the engines appear to be the same.
I just purchased a new L4300, predecessor to the L4400 and am quite happy with it. However, I got in on a model clearout sales incentive that probably saved me $4K over the L4330 you're being quoted. The above list was compiled using what I can remember from an L4400 spec sheet I saw here on the web plus what I know about my tractor.
Only comparable Grand L machine my dealer had at the time was an L4630 HST which was an even bigger jump...besides I wanted gear, not HST.
You'll love either, but for less than $1700 difference, I'd go for the L4330 if I could swing it.
Bob
</font><font color="blue" class="small">( What kind of prices were you given on these two machines? The reason I ask is that I am looking at those two as well. )</font>
Misplaced my quote but it was something like 21,300 for the l4330dt plus 650 for the remote. It was posted that this is not a bad deal. Do you have better quote? I noticed someone posting about 24,000 for the next model up WITH GST transmission.
mike
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
377811 (A48836)
377811 (A48836)
Hitch-Hiker 3600-R (A50120)
Hitch-Hiker 3600-R...
Wood Fence Posts (A50121)
Wood Fence Posts...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
