The four wheel drive worked the last time I used it while plowing snow with the bucket last winter. After finishing mowing for the season, I reinstalled the bucket. I tried to engage the four wheel drive. The lever moved into the proper position but it did not engage the four wheel drive and the 4 wheel drive light on the dash readout also was not lit. I used the bucket to lift the front end with the lever in the four wheel drive position. I rotated one tire with the opposite tire spinning also. I also looked underneath the tractor and the metal linkage did not look bent. I noticed there was a split pin from the lever outside lever to the internal connection but did not drive it out to see if it was broken. Are there any suggestions on what may be the problem and what I may be able to do to check it further. The tractor is a 2004 model with less than 200 hours on it. I can't believe this should be failing this soon.
