Traction Kubota L4310 will not shift into 4x4
   / Kubota L4310 will not shift into 4x4 #1
bkcushman
I've got a L4310 that has about 1500 hours on it. It operates in 2x4 as it should however I can not shift it into 4x4, the lever moves and their are no noises, anyone have any ideas before I take it to the dealer? Thanks
   / Kubota L4310 will not shift into 4x4 #2
Is the tractor new to you or have you had it a while and know how the 4x4 shifter is supposed to work and feel? One of my tractors is pretty much the same and there's an obvious in and out position for that shifter.
I'd suggest the first thing would probably be for someone to get underneath and look at the linkage to see if it's bent, broken, has come apart or loose somewhere, or is bound up with accumulated crud. Those should be pretty obvious upon inspection and probably the easiest to fix. Maybe a helper can operate the 4x4 lever while you or whoever is observing underneath, on a flat, level surface with the engine off and brakes locked, of course. If it all looks OK and seems to operate normally external to the transmission, it indicates something is likely wrong internally.
By the way, welcome to TBN.
   / Kubota L4310 will not shift into 4x4 #3
On my L4240, I need to sometimes rock it back and forth a bit to get the 4x4 to engage and disengage. The main caution I've heard is to avoid forcing the linkage. I like Grandad4's advice too.
Gravity Wagon (A49251)
72in Large Capacity Bucket (A49251)
72in Large...
2020 Bobcat T66 Skid Steer (A49251)
2020 Bobcat T66...
1997 Mack RD688S Truck (A47369)
1997 Mack RD688S...
2012 Ford Escape SUV (A46684)
2012 Ford Escape...
48" Pallet Forks  (A47371)
48" Pallet Forks...
