Kubota L39tlb 200 hr service
   / Kubota L39tlb 200 hr service #1
Carpenter
N.E. Oregon
PT425, Kubota L39 TLB
I've had this tractor for quite a while. I bought it for a construction project, and then due to health issues it's been mostly resting in the barn. It needs it's 200 hr service and I'm having a hard time finding anyone to do it. Any tricks to doing this myself? I haven't been able to find a youtube video. Thanks.
   / Kubota L39tlb 200 hr service #2
yes, the hydraulic filters can be very difficult to remove. Search this forum for many discussions. Be prepared with tools, sturdy strap wrenches, and cheaters. And a wrestling match. Check that the mounting nipple is tight into the housing before putting on the new filter. Do not overtighten.
Mght as well use Kubota's best transhydraulic oil. SuperUDT2. Sure, it's overkill for the L39 tranny, but the money you could save isn't worth the hassles you could have.
I live in a dry climate, the tractor is covered, and I am careful with the fuel I buy. So I never have replaced the fuel filter. I always replace both air filters and the engine oil filter.
I wouldn't be surprised if yours has been sitting that it needs a new battery. They self-discharge, and if they sit long discharged they are never right again.
For the front axle I use any main brand 80w-90 gear oil - which is approx. the same weight as 30 wt engine oil.
For engine oil everyone has preferences. Mine used to be 15w-40 Rotella diesel oil. Now I tend to use a full synthetic in the 15w-40 range. But I've never seen or heard of an engine damaged by good multiweight oil of any kind.
Use a hand lever pump cartridge grease gun on all the zerks. I use JD general purpose polyurea grease "the green grease" just about everywhere.
Good luck,
Go slow take your time & enjoy the project.
rScotty
   / Kubota L39tlb 200 hr service #3
Good luck,
rScotty
With 4 machines to grease, if only greasing each machine once each year, you really should treat yourself to a Milwaukee, or DeWalt battery powered grease gun.
If you do so, you will NEVER go back to a lever style gun.
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53472)
PENDING SELLER...
2025 New/Unused 72in Skid Steer Sickle Bar Mower (A51573)
2025 New/Unused...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A51572)
2014 Ford F-150...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2012 JOHN DEERE 310SJ BACKHOE (A52472)
2012 JOHN DEERE...
