Kubota L39 neutral switch
   / Kubota L39 neutral switch #1
MarkV
Super Member
Cedartown, Ga and N. Ga mountains
1998 Kubota B21, 2005 Kubota L39
Hi TBN friends. My Kubota L39 will go into neutral but the neutral light will not come on and I have to find the "sweet spot" for the starter to engage. I would guess this has to do with the transmission safety switch either gong bad or some adjustment. Can anyone offer suggestions as to its location and if their is an adjustment or by pass to the switch.
Thanks in advance,
MarkV
   / Kubota L39 neutral switch #2
Just saw you note. I'll check in my manuals tomorrow and let you know.
   / Kubota L39 neutral switch #3
It's usually attached to the selector itself. On my GST, the gear selector does not have one... just the forward/reverse/neutral lever. Though that was 25 years ago. There is some adjustment, but my switch itself was bad. I connected the two wires together for now... that was 3 years ago.
Thanks guys. Robstapes if you have the service manual and would check that would be a great help.
MarkV
CM Trucks Utility Bed (A49461)
CM Trucks Utility...
2014 Whisper Watt Generator (A49461)
2014 Whisper Watt...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
PALLET OF FUSION EQUIPMENT (A50854)
PALLET OF FUSION...
