Kubota L39 backhoe, GST light started flashing on control panel, tractor will not mov
   / Kubota L39 backhoe, GST light started flashing on control panel, tractor will not mov #1
rob62
Rockdale, Texas
Kubota L39
I was using the backhoe- L39 tractor and the GST light started flashing on the control panel. Error 61 through 66 starter flashing on panel, along with 1 7 8 NG, 2 9 10 NG, 3 4 11 NG, 5 6 12 NG, 1 - - - 6 NG, 3579 NG. The hydraulics still work, I used the backhoe to pull the tractor to a good spot. I unhooked the battery, {thinking by doing this it may rest the computer or something} and changed the hydraulic filter, toped of hydraulic oil level, restarted tractor, same thing, errors keep flashing on display, and transmission will not engage, the tractor will not move, but the engine sounds good. There is about 900 hrs on tractor, and I am the only one that has driven this tractor.
I sure could use some advice to get going again.
   / Kubota L39 backhoe, GST light started flashing on control panel, tractor will not mov #2
Rob62
I am having the same problem, How did your fix it?
Williewillnot
   / Kubota L39 backhoe, GST light started flashing on control panel, tractor will not mov #3
check your fuses, my 3130 did this.
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51243)
(NEW) 2025 DOWN 2...
2005 GEHL CTL70 TURBO SKID STEER (A51242)
2005 GEHL CTL70...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2015 International 4400 Cab & Chassis (A47384)
2015 International...
