22West
Greetings Folks,
Long term reader but first time poster. I’m hoping to get some help troubleshooting a low pressure hydraulic issue on my Kubota L3830D tractor. I apologies about the long post, but I hope this is detailed enough for feedback and also helpful for future readers.
The issue seems to be that the hydraulic system on the tractor will not create enough pressure to operate the FEL.
I recently added a Westendorf FEL to the tractor. After the install and doing the final hose connections (following the manufactures guidelines), I raised and lowered the bucket a few times successfully to test the loader out. After 4-5 reps the loader suddenly stopped raising the bucket at all and would only lower. The bucket will now only curl, but at a rate that can only be described in inches per minute. The only functions I have on the FEL are the ones that gravity helps with.
Thus began my saga of troubleshooting:
At first I thought that the hydraulic system was low on fluid since the hoses were dry when I installed them and I lost a little bit of fluid when installing the new connection block on the tractors front hydraulic connection block. Got some Kubota UDT2 fluid and topped it off. No change.
Thinking I had connected some of the hoses incorrectly, I went back to the FEL hydraulic install instructions and even looked up the L3800 service manual to verify that the right hoses were in the right place. Everything is connected correctly, still no joy.
Next I ordered a hydraulic pressure gauge test set. To eliminate the new FEL as an issue, I disconnected the FEL lines and connected a test gauge directly to the ‘pressure out’ port on the tractors front hydraulic connection block. That’s when I discovered that the system has very low pressure. At idle I have 50-75psi, at 1000rpm I have 100psi, and at 2000rpm I have 600psi. The most I have seen is about 800psi when operating the 3pt to max height to trip the pressure relief valve for the rear cylinders. The service manual says the system should create aprox 2500psi at 2700rpm. Even with math not being my strongest subject, this seems like an issue.
Additionally I have replace the hydraulic fluid filter in case there was a clog causing insufficient fluid to reach the pump. I have also taken out and cleaned the pressure relief valve located on the front hydraulic connection block in case there was debris casing the valve to stick open.
Interestingly enough the power steering seems unaffected and the 3pt in the read raises and lowers with the same speed it has in years past.
Any help on troubleshooting would be appreciated. I am fairly mechanically inclined, but new to the hydraulics on this tractor. Not sure what to test next. After looking ove the tractor and the service manual, there doesn’t seem like much left other than the hydraulic pump itself. Could the pump be bad/worn out with only around 500 hrs on it? How would you test this?
