Kubota l3800 fel and backhoe dead need help
   / Kubota l3800 fel and backhoe dead need help #1
Codfar
Duck town tn
2012 kubota l3800
I have a 2012 kubota l3800. It has 52 hours on it. I was using it today and the fel wouldn't lift. It would lift and curl but not lift straight up. The backhoe won't do anything. I noticed a na soundng from under the tractor that stops when the wobble stick is engaged. Could this be symptoms of stopped up filters or is a hydro pump in need of repair. Fluid levels are all fine and it hasn't ran hot. I lowered the boom on the hoe so I can't get it to raise to take it to the stealer ship for its 50 hour service. Any suggestions are greatly appreciated.
   / Kubota l3800 fel and backhoe dead need help #2
Check your Quick disconnects unplug then replug them in.
Will do
   / Kubota l3800 fel and backhoe dead need help #4
Also try "lowering" the three point hitch lever,sounds like its going into relief.
Got it fixed. Raised and lowered everything. Put everything in neutral. Wobbled and wiggled and disconnected and reconnected everything I could find. Cranked it up and it made the funny noise for about 5 seconds and stopped. After it stopped everything was working. Thanks for the tips. What a relief.
(10) IH Suitcase Weights (A50515)
(10) IH Suitcase...
2019 Freightliner M2 106 Landscape Dump Truck (A50323)
2019 Freightliner...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
Woods Brush Bull 7' 3 pt Mower (A50514)
Woods Brush Bull...
Agri Metal Tuff Vac 5000 (A50774)
Agri Metal Tuff...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
