Kubota L3710
   / Kubota L3710 #1
sherpa
Platinum Member
North Carolina Mountains
2004 NH TC33D & 2014 NH Boomer 24
I have an appointment to look at a used L3710 Tuesday and cant find much information on this site about them. It has 140 hrs and HST trans and FEL. What is a L3710, how much horse power does it have? What year is this L3710? Can someone tell me about the L3710? Why do they not make it any longer? I have been looking at a new L3130 and like it a lot, whats the difference between a L3710 and the new L3130? Does the L3710 have the intellipanel like the L3130?
Sherpa
   / Kubota L3710 #2
Here is information from <font color="orange"> Kubota's </font> site.
L3710HST, Production started in 1998, Hydro, 30.0 PTO HP
The L**30 series tractors replaced the L**10 series in 2002.
The 3710 does not have intellipanel.
By doing a search "L3710" at top of page you will get a lot of responses on this tractor.
   / Kubota L3710 #3
Well, lets see, I owned a L3710 before I traded it on a 5030. The 3710 has around 32 pto horsepower with the HST. The dash is analog which isn't all bad and the loader has a 3 position valve.
The front axle is old style (4wd) with a drag link instead of the ram type steering found on the newer L Series. The bushing in the pittman arm tends to wear out and get sloppy, especially if you do a lot of FEL work with it..
On the plus side, it's a good reliable tractor. I just needed some more ponies so I sold it. Besides, it didn't have a cab. Even the new Kioti's have the ram type steering now.
If you can, lift the front end off the ground with the FEL, grab a tire and try to move the steering wheel with the tire (with the engine off) (back and forth). Observe the drag link and pittman arm (right under the front of the engine just behind the radiator). If the pittman arm moves without the steering wheel moving, the bushing is worn. If the bushing is worn, the front end will shimmy on pavement at speed and the steering wheel will feel vague when working the tractor.
   / Kubota L3710
Daryl,
Does this happen on all the tractors with the old style (4wd) with a drag link or is it something rare? Could the bushing be worn out at 140 hours? Is that bushing hard to replace? Is the bushing problem the reason they went to the new ram style?
Sherpa
   / Kubota L3710 #5
</font><font color="blue" class="small">( Does this happen on all the tractors with the old style (4wd) with a drag link or is it something rare? Could the bushing be worn out at 140 hours? Is that bushing hard to replace? Is the bushing problem the reason they went to the new ram style?
Sherpa )</font>
That is hard to answer. I have 5 Kubota's, all with increasing horsepower. Only the 5030 has had the ram steering. All the others had the drag link. It's suffice to say that I only noticed the slop on the 3710, but it was the largest Kubota I owned prior to the 5030 and I actually farmed with the 3710. All the previous ones were just used for utility work around the farm, while the other tractors were used for field work. I wanted to consolidate to one brand so in as much as the Kubota's were reliable and trouble free, I went orange.
My 3710 had a grease fitting on the drag link and I believe a bronze bush though I sold it without rebuilding it. I attributed the slop to quite a bit of FEL work, mainly round bales which put a strain on the front axle. I use a bale spear the attaches to the bucket. That puts the weight out in front of the bucket quite a bit. With the 3710, I always had to have a box blade on the back to counter weight the tractor, or I'd lift the rear wheels off the ground. That equates to a lot of weight bearing down on the front axle, pivot points and the steering mechanism. My 3710 gave me good service and at 500+ hours, it was getting time for a re-bush.
I don't think 140 hours would cause appreciable wear, that is, if the tractor was serviced in a timely manner. Like I said, it's easy to check the front end, just use the procedure I outlined in my post. That will tell you right away.
I'd want to see the receipts for all service performed and by all means take a sample of the oil (engine and transmission)and do a spectroscopic analysis on it as well as a coolant sample burn.
I never buy a used prime mover without doing a spectro analysis. The burn will tell you everything that's going on inside the engine, transmission and radiator, what if any problems there are and if the previous owner maintaned the unit or cut corners and ignored the maintanance schedule.
I think the new ram style actuation isn't about a perceived problem, rather it's just an engineering improvement. Besides, it's a lot less intrinsic parts and moveable joints. Besides, the ram system provides a certain amount of inherent dampening from shock transmitted through the steering gear. On the down side, the ram system is probably much more expensive to repair or replace than a cast drag link or tie rods.
   / Kubota L3710
Here is a picture, whats it worth? It is a 3710, HST, 141 hrs, loader and looks and runs like new. Talk me out of buying this tractor.
Sherpa
   / Kubota L3710
Pic wont post but I still need help, what is it worth?
Sherpa
   / Kubota L3710 #8
I don't see a picture. Actually I don't have to.
With anything used and I mean ANYTHING, it's buyer beware. If you are satisfied that everything is okay, it's your money, not mine. You can destroy a tractor internally in 5 hours by abuse, longer with neglect. Nice paint and good rubber means nothing.
Farmers call that a "five gallon finish". It may be a turd, but it's pretty on the outside.
Seriously, if you are satisfied, that's all that counts. If it was me, I'd do the analysis on the lubes and water just to be sure, but then you are not me.
If you don't want to do the spectro analysis then just lift the front end off the ground and check the play in the drag link. That will give you a good idea of how hard the 141 hours were.
have fun....
   / Kubota L3710
I did the front end test like you said, it was tight as a new one.
Sherpa
2011 MAMMOTH UTILITY (A50854)
2011 MAMMOTH...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
