Kubota L3710 HST no start
   / Kubota L3710 HST no start #1
shorthairtwin
South Dakota
Kubota L3710D HST
I have a Kubota L3710 tractor that will not start and I am looking for some assistance. I had used it several times this day with no issues but now it will not start.
When I turn the ignition key to the on position the glow plug dash light works as well as the battery and oil pressure lights and head lights, flashers and blinkers. When I turn the key to the start position nothing happens, no cranking at all. I removed and cleaned the battery cables and terminals, replaced the starter relay and clutch pedal safety switch with no luck or change in the problem. I have checked my ignition switch with a test light and have constant power at the larger center terminal and have power on the smaller terminals as I rotate the switch from the on position and start position. I have found that the small wire on the starter does not have any power at all when I turn the ignition switch to the start position. Does anyone have any ideas on how the power flows from the ignition switch to the small wire on the starter?
   / Kubota L3710 HST no start #2
My L3700 did the same exact thing yesterday.
   / Kubota L3710 HST no start #3
sounds like safety switch, maybe try wiggling hst pedals
Awesome that was it and it starts up fine now!!!!!!!! The pedal must have been stuck slightly in the forward position. Thanks for the help and quick reply!!
2012 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2012 VOLVO VNL...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
(INOPERABLE) MAROOKA (A50854)
(INOPERABLE)...
2021 Case Trident 5550 Spreader (A51039)
2021 Case Trident...
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
