Kubota L355SS - Remove front steering knuckle
   / Kubota L355SS - Remove front steering knuckle #1
mchild
My L355 is a four wheel drive model. As such, the front wheel hubs attach to the stationary front axle tube at a square flange with four bolts and two nuts on studs. I am trying to remove the entire hub assembly in order to fix an oil leak at the steering pivot point. It looks to me the only way to get the pivot point apart is to remove the entire hub assembly.
I have removed the four bolts and two nuts from the connecting flange, but have been unable to get the hub assembly to move off the axle end. I have used a good sized hammer to try and jar it loose and tried various methods of trying to pull it off, but to no avail. I have the shop manual and it makes the removal sound as easy as removing the attachment bolts and nuts and then simply sliding the hub assembly off - of course.
If anyone who has done this job could provide me with some guidance it is greatly appreciated.
Thank you.
  • Kubota Hub.pdf
2014 Chevrolet Express Cargo Van (A50323)
2014 Chevrolet...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
J & M 30' Head Cart (A50514)
J & M 30' Head...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52128)
Kubota 24in Quick...
