Kubota L3550 tranny problems
/ Kubota L3550 tranny problems #1
kylemartin
mass
Kubota L3550 and B2150
need some help transmission is stuck in third gear and it won't change but I still have high gear any suggestions?
fluid is good and so is the linkage,as for the filter not a clue
/ Kubota L3550 tranny problems #4
Is that the Hydroshuttle transmission? I have a L3750 which has 4 ranges on the right hand side by the seat. Then you shift forward and reverse up on the column. There are a lot more Kubota fans on here that might have other troubleshooting ideas. Reverse is working ok?
/ Kubota L3550 tranny problems #5
I'm thinking that the shift fork lever has come out of it's proper location. Does it lock up when you put it in another gear?
If this is the case you will have to remove the shift cover and check for a worn shift fork or rail.
it has the hydroshuttle transmission and reverse works. It doesn't lock up when i change gears because it is stuck somewhere in between gears
/ Kubota L3550 tranny problems #7
Does the PTO engage? Not that it matters much I am just checking for things that I would try. The shift fork scenario sounds plausible. I haven't had any problems with my machine like that at all.
Have you called any Kubota service centers and picked their brains?
yea the pto does engage but i haven't been able to contact Kubota yet
no the thing has to be used everyday and i just can't find the time to work on it.
I am pretty sure it is the shift fork lever but I can't work on it right now thanks for the help but I am open to new ideas.
i kinda hacked it but i got it to shift again and every now and then it wont but there has to be something i am missing.
/ Kubota L3550 tranny problems #13
When you pull the shift cover off you will see a roll pin holding shift arm to the shaft it is either held in with a cir-clip or a wire running through the center of it. That roll pin is broken. Kubota makes a solid pin for this, or you line the holes up, open the hole up with a 1/4" drill bit, get a piece of drill rod and make your own pin and cut your own snap-ring groove in the arm and put it back together. Or for the quick repair drive out to out roll pin and drive in a new 6mm roll pin and know that you'll be doing it again at some point.
Brian
ROLL OF 6' CHAINLINK FENCE (A62131)
ROLL OF 6'...
2021 HUNTER WHEEL BALANCER (A59909)
2021 HUNTER WHEEL...
2011 Ford F350 Service Truck (A63116)
2011 Ford F350...
UNUSED 2026 INDUSTRIAS AMERICA 7014R 7'X14' DUMP T (A62130)
UNUSED 2026...
Arrow Quip 5500LV Cattle Chute (A64047)
Arrow Quip 5500LV...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
