Kubota L35 no start questions
   / Kubota L35 no start questions #1
Kcorey
North Madison, CT
Hello I just purchased a Kubota L35. It will not crank over wth the key, I was able to put in a push bottom start to get it to run. I am in need of a wiring schematic for the machine so I can trace the wires .
Also the hour meter is not currently working. What drives the hour meter? Any help is appreciated and does anyone know the cheapest place to get a service manual for the machine .
I am pretty sure I do since when I turn key on the battery light on dash comes on the the timer relay clicks
   / Kubota L35 no start questions #4
That same 12 volts then goes from the key switch through the start terminal to the various safety interlock switches and ultimately arrives at the starter solenoid... you could take a volt ohm meter and work from either end untill you find the open...
   / Kubota L35 no start questions #6
Most common fault for no crank is PTO engaged (or slightly out of position) and Neutral switch (or slightly out of position), and clutch switch. Check these first.
However, if you don't have a working hour meter then you could be missing 12v somewhere, which also could be the feed for the starter. Pull all fuses, check them, and rotate them before replacing. This give a new contact area on a possibly corroded fuse.
Found the no crank issue... It was a bad PTO switch . Not sure if that fixed my hour meter issue as I have the valve cover over to adjust the valves .
2006 MACK CV713 KILL TRUCK (A50854)
2006 MACK CV713...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
(2) 15X8 RIG MATS (A50854)
(2) 15X8 RIG MATS...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2013 Nissan Pathfinder (A50324)
2013 Nissan...
