kubota l35 fwd problems
   / kubota l35 fwd problems #1
dave2672
keeseville ,ny
kubota l35
hi. the problem is the tractor runs fine in 2wd then switch to 4wd and the prob starts .1st and 2nd gear seem fine 3rd and up not so good worse when under a load.kinda sounds like a dozer lug.lug.lug and so on.in the trans.or transfre case?maybe not enguaging fully in gear.help would be appreciated thanks. david
   / kubota l35 fwd problems #2
That doesn't sound right, but can you explain a little more? Is it new to you or have you had it for a while? What rpm? Are hydraulics working OK? Is everything normal in all gears if you're in 2wd? Tire pressure OK? Engine starts and runs OK until you get into higher gears and 4wd? Engine smoking or overheating? Burns oil? You're not using the 4wd on dry pavement, right?
UNUSED AGT H15R EXCAVATOR (A51243)
UNUSED AGT H15R...
Land Honor 3 pt Disk (A50514)
Land Honor 3 pt...
Comfort Chute H Series Hoof Trimming Trailer (A50774)
Comfort Chute H...
2011 Toyota Sienna Van (A50324)
2011 Toyota Sienna...
71059 (A49346)
71059 (A49346)
Toro Workman Cart (A50322)
Toro Workman Cart...
