Kubota L35 doesn't turn over
   / Kubota L35 doesn't turn over #1
devilpeakubota
I replaced some Hydro lines, and then drove the tractor up to my driveway. I noticed the gear selector was hard to move/shift. I added hydro/tran fluid, due to loosing fluid during the Hydro lines change, and tried to start and it will not turn over. Forward/reverse selector is in neutral. I forced the gear selector to neutral. Still no help. Didn't expect this problem.
I will check the battery is fully charged. But I am suspecting their is an electronic defeat going on here? And somehow the loss of fluid is part of the problem?
Any ideas?
   / Kubota L35 doesn't turn over #2
have you checked the seat safety switch, and the pto safety switch?
There is no seat safety on the L35, well the one I have, I think, 1993 or there abouts. The PTO is in the off position, which is the default position for start, I would think.
I never had this problem before. I guess I'll check the battery, see if that is part of the problem.
I figured out the problem. The PTO wires had been damaged by mice. It created an open in the starting circuit. Seems the PTO and FWD/RVRS selector have a switch that disables the starter.
I spliced the wires, and now park the tractor in a different location to help prevent mice running all over the tractor.
The gear selector, well now that is another problem completely, new thread to follow.
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52128)
Kubota 24in Quick...
Tennant S30 Ride-On Sweeper (A49346)
Tennant S30...
2016 Ford F-150 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
2013 Hyundai Sonata Hybrid Sedan (A50324)
2013 Hyundai...
2014 Kia Cadenza Sedan (A50324)
2014 Kia Cadenza...
