Kubota L35 3-pt hitch not lifting
   / Kubota L35 3-pt hitch not lifting #1
the Peej
The lift arms on my L-35 won't move. with nothing hooked up they dont even try, I can move them by hand but nothing on there own. I have the diverter pulled out in the 3pt position and they don't move I tried it in the backhoe position and no differance. I checked all the linkage and everything apears correct. I checked the diverter valve and confirmed it's rotating fully stop to stop.
A little history, I bought the machine this spring from a friend who bought it new. When I got it the relief valve on the backhoe had rusted out and was leaking. It would not drive until I added 5 gallons of oil now everything works as and shifts as it should. I don't think he ever had the backhoe off, the latches were frozen and needed heat from a torch to release. I bought the 3pt hitch kit and would like to start using it.
Any advice on where to start? Should I pull apart the diverter valve in inspect it?
Update, I brought it to the dealer last week and just heard back from them. Somehow the piston became disconnected and has been riding on the ring gear. They need to open up the rear end to see the extent of the damage. not the easy fix I was hoping for.
8' 3 pt Disk (A50515)
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
1989 W-W Stock Trailer (A50514)
1989 W-W Stock...
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
