Most likely just crud, dirt, moisture on the caps of each spool, located on the bottom of the valve.
It can be as simple as taking the caps off, clean everything, lubricate and reassemble. Just be aware that there are some balls under pressure that can pop out and never be found again. It depends on the design of the detent.
