Kubota L3240 Front Differential Case, greasing rear support
   / Kubota L3240 Front Differential Case, greasing rear support #1
JoeL3240
I have a 2008 L3240 HST Tractor. The Front Differential case is supported by the Front Axle Support and the Rear Axle Support. I can not seem to get grease into the Rear Axle Support. I have removed the grease fitting and pumped grease through it so the grease fitting works fine. With the grease fitting off I have removed all the grease from what appears to be a blind hole about 3/8" in diameter by about 5/8" deep. Is there any reason why I can not get grease into this Front Differential Case - Rear Axle Support. The Front Axle support once I remove the air plug takes grease fine.
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
2014 John Deere 8360R MFWD Tractor (A50657)
2014 John Deere...
Unused 2025 CFG QK16R Mini Excavator (A49461)
Unused 2025 CFG...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
