Kubota L3130DT work light wiring
   / Kubota L3130DT work light wiring #1
b3bt459
Caledonia, MI
Kubota
The work light on my L3130DT stopped 'working'. There's no power at the connector. I checked the fuse (top left) labelled "work light". The fuse was good, but when I pulled it, by console went off. That was odd, so I check the fuse label console. That fuse was also good. The work light wires are yellow & black. There are no such wires coming into the fuse box. a) Does anyone know where the work light power comes from? b) is is possible my [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] is mislabeled or mis-wired?
   / Kubota L3130DT work light wiring #2
I have no idea how your tractor is wired. My L2501 worklight connector is powered through the ignition switch. Yes, I have a separate fuse marked Work Light. I suspect power comes from the switch to the fuse panel then separates out via the various fuses. Since your fuse is good I suggest checking to see if there's any power at the fuse with the key turned on. That may help narrow it down.
My worklight was not, never was switched. The fuse labeled worklight is switched and has power with the key on. The confusing thing is, when the fuse is removed the console goes out. Thanks for the input.
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
John Deere 4000 Tractor (RUNS) (A50774)
John Deere 4000...
Wolverine Mini Skid Steer Stump Grapple (A50515)
Wolverine Mini...
Unused 2025 CFG Industrial QNT50R Mini Excavator (A50322)
Unused 2025 CFG...
Terry 12ft Aluminum Jonboat (A50324)
Terry 12ft...
Mower King Q.A Pallet Forks (A50121)
Mower King Q.A...
