Tolarkubota
- Joined
- Feb 20, 2011
- Messages
- 2
- Tractor
- Kunitz l 3010
Kubota L3010 HST leaking UDT from plunger underneath engine!
Ok , I am new here...hope someone can point me in the right direction.Got onto the 3010 today and noticed a large puddle of hydraulic fluid underneath the engine. The tractor still operates...but the source of the leak appears to becoming from this round tube/cover that passes between the oil pan and goes to the front axle..Also dripping from the plunger looking valve drain under in the same area. Are there lines inside this round housing that supply fluid and power to the front axle or is it a drive shaft.....I have not tried tearing into it yet....where should I start...or is it a seal in there...if I fill up the fluid everything works fine...so it's not my pump or anything....just a slow leak....like drip..drip...drip...its not gushing out from underneath.
Thanks for any help
Nate
Thanks for any help
Nate
