Kubota L3000DT and L3130GST
   / Kubota L3000DT and L3130GST #1
Da1Bar
Idaho
Kubota L2800
I notice that a local dealer has an inventory of several of these tractors. I am in the market for a tractor in this size range, but I don't see much information on them on the Kubota Web Site. Can some informed tractor person give me an idea of what I should expect to pay for them and if they are suited for pulling heavy loads. My first use will be as a skidder as I am currently logging my property. Also is there an aftermarket acc that will attach to the three point to take some of the weight off of the ground when pulling heavy loads. Thanks, Dave
   / Kubota L3000DT and L3130GST #2
I've an L3130 HST which has been used to haul around 40 logs (so far) out of our woodland. Lengths are mostly 18 feet and diameter is up to 28 inches. We used cables and a comealong to get the logs up to the trails where the tractor could be harnessed, then a logging arch chained to the pto to haul the logs to two log decks. We have some steep slopes so we have a deck on the higher land and one at low level to avoid hauling logs up the hill. The L3130 coped ok for the most part but there was the odd time I could have used more weight and power. We needed the fel for balance when we were skidding logs using the 3ph.
   / Kubota L3000DT and L3130GST #3
Hi da and inv -
As Inveresk just proved, 31 diesel hp can drag some big logs (very nicely done). There is SO much that goes into a tractor-buying decision. Yes, there will be times when you had more weight and power, no doubt about it. I have a 5030 set up for tree work, and sometimes I wish that too. But if that size tractor will serve all of your other needs nicely, and you're not going into the logging business, I think you're on a good course.
For some ideas, maybe check out my post "5030 skidder etc" in Kubota Owning and Operating. I have a rear grapple that pics logs right up off the ground, but for skidding them I would recommend you look at one called the Beaver Squeezer. Forget the Iron & Oak grapple distributed through Bailey's, it's junk.
You should be able to find a lot of info on the Kubota site - it took me a while at first to find the grand L's, but there's a lot there.
And think hard about getting a hydro tranny. No shifting, incredible control under all conditions, infinite speed control, no slipping the clutch, easy to maneuver in tight spaces, easy to creep along with high heavy loads, it goes on and on. Unless you're going to be plowing fields all day long, the only good reason not to get it is if you just can't spend the money. But borrow it or steal it if you have to.
Anyway, good luck, have fun, and be careful!
   / Kubota L3000DT and L3130GST #4
Dave,
I have a L3130 HST with a Farmi skidder combination. Have pulled anything I have hooked on to (within reason). I even pulled a loaded cement truck out of my garage footers thanks to a sturdy tree. Very happy with the L3130 for my applications. Common sense should be part of any actions with your new tractor (which ever one). Logging can be extremely hazardous if not done properly.
Keep safe,
David
   / Kubota L3000DT and L3130GST #5
I have had my L3000DT for 4 years now and prior to this tractor I had an 8N for over 20 years. I also have a protable saw mill and we have heated our home with only wood for 31 years.
So, cutting and hauling logs is a primary use for the tractor. The 8N was a very stable tractor in the woods. Remember tractors were designed to operate in fields or lawns which are not all flat but offer less obstructions to drive over than the woods.
If you are going to use a tractor for logging consider a 3PH winch, I have a small Farmi. This opens the range of operation and keeps the tractor on your skid trails. I also made a logging arch to carry logs out of the woods with, this cuts down on damage done to the ground, cleaner logs, and less power needed to move material out to the landing. It is also safer because the log is less likely to get caught on something while you are pulling it out.
One limiting factor is size and weight you will not be able to pull what a skidder can. There is also no cage on a farm tractor to protect you from falling objects and you need to watch out for saplings that turn to spears and come at you from the ground. Farm tires have good traction but are not as tough as forestry equipment tires.
If you pay attention you can do a lot of work with one of these tractors.
Randy
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
FLARE LINE SKID (A50854)
FLARE LINE SKID...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
