Kubota L2950
   / Kubota L2950 #1
double hunter
Ford 1715
New to me 1991 Kubota L2950 4 wheel drive, I just purchased a 1991 L2950 and hope someone can help me with a couple issues, first are the indicator lights, all 3 come on when the ignition is turned on, after the engine cranks the water and voltage light stay on, looked for the sending unit for the water temp. and could not find, what would cause the voltage light to stay on, the tractor had been sitting for a while when I purchased it, the owner said the battery probably needs replacing, but put a charge on battery and it has been cranking, second, the rear wheels look a little narrow to me, the valve stem is on the inside of the rim, looks like the wheels may have been reversed, I would think the vaalve stems should be on the outside, any help appreciated.
   / Kubota L2950 #2
On the L2950 I had the Ag wheels had the valve stems on the inside. A little inconvenient, but I usually only had to check them once or twice a year.
Sorry I never had any indicator light issues, I can't help you with that.
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A51039)
2020 Massey...
2013 FELLING  SKINNYNECK TA LOWBOY (A50854)
2013 FELLING...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
