Kubota L2950 loader bucket won't roll back!
   / Kubota L2950 loader bucket won't roll back! #1
gterbo
ridgway pa
johnd deere 110 tlb
Hello, I have an older kubota L2950 tractor Loader which has lead a hard life in Montana. Recently while pushing rocks and stumps the front bucket roll back function totally quit working. There are no oil leaks or bad hoses, the cylinders are not leaking, and I doubt both could have failed simultaneously, the linkages on the valve body are working. The up and down function of the loader arms works correctly and I can detect a pressure pulse at the hose ends where they connect to the dump cylinders but absolutely will not roll back the bucket. I am wondering if there are multiple relief valves for the different bucket functions, one of which may have failed or if I could have a bad valve body that is showing pressure but not activating cylinder. Anybody have any ideas or knowledge of this system and how to repair?
   / Kubota L2950 loader bucket won't roll back! #2
Try disconnecting and connecting the quick attach hook-ups. If that makes no difference then switch the dump/curl quick attachments to see if the curl function works and the dump function doesn't (the reverse of what is happening now). Mark the suspect line with a twist tie or the like.
Even further, you can try switching the up and down functions to the curl and dump cylinders. That will at least diagnose where the problem lies. At that point you can address a fix.
Thanks for the reply. Actually, I just recently,within the past couple months, replaced two of the quick couplers at the lower loader arm. I am wondering if perhaps in the brush one of them came partially unhooked.
I should have thought to check this. As often the case we don't check the simple first. I appreciate the tip.
   / Kubota L2950 loader bucket won't roll back! #4
Had the same thing happen to me a month ago. Started tracing the lines back and when I gave one of them a tug it popped right out. Problem solved...
2011 Toyota Sienna Van (A50324)
2011 Toyota Sienna...
434669 (A48836)
434669 (A48836)
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2014 Chevrolet Express Cargo Van (A50323)
2014 Chevrolet...
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52128)
2022 Down2Earth...
