kubota l295 loader attaching
   / kubota l295 loader attaching #1
stepdoctor
troutville virginia
kubota L295, JD 40W, International 140
I recently bought a L295 kubota with a loader and backhoe, both the loader and backhoe hydraulics are run by a PTO driven hyd. pump. It does not have a live pto, so everytime I depress the clutch the loader does not work. Want to hook up the hydraulics directly to the tractor. Need to know what to do or what ports to connect to make the loader work off the tractor hydraulics. Please help. Thanks
   / kubota l295 loader attaching #2
You should have about 5.5 GPM's on that tractor, so just connect the FEL valve to the pump pump output. Use the PTO pump for the BH.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
1999-2010 Ford Pickup Truck Bed (A49461)
1999-2010 Ford...
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
2012 FREIGHTLINER M2 TANDEM AXLE DUMP TRUCK WITH A SNOW PLOW (A51222)
2012 FREIGHTLINER...
2018 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A51219)
2018 VOLVO...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
