Brad602
Kubota L2900 won't start. Worked fine a couple of weeks ago, when last used. Emergency flashers work fine, but the headlights do not work at all. Nothing lights up on dash when turned to the on position. Charging battery make no difference. There is no noise whatsoever from the starter when put in the start position. Seems like it might be a safety interlock but all attempts to wiggle the shifter to be sure it is in neutral or wiggle the PTO switch produce nothing. If it is a bid ignition switch how do I test it? Any other ideas as to what may be the cause? Brad602
