Kubota L2900 Throttle Speed
   / Kubota L2900 Throttle Speed #1
BackwoodsMan
Macungie, Pennsylvania
Kubota L2900
I have put 20 hours on the used Kubota L2900 I bought last September. I was really set on buying a HST tractor, but this one came along and was in mint condition. I figured the GST trans would be an OK compromise and for the most part it has been working out fine. My question is how to manage the throttle speed. The tractor has a lever on the column and a foot pedal. I have been keeping the column throttle at minimal setting, about 800 rpm. I then use the foot throttle to rev up to accommodate the work at hand. The only time I raise the column throttle is when I need a fixed rpm to run the backhoe. I am curious how other L2900 owners work the throttle.
   / Kubota L2900 Throttle Speed #2
You are using it correctly. I believe the manual adjustment also is used for stationary implements on the PTO like generators, large water pumps, and portable sprayers. I also have a backhoe on my L-35 Kubota, and idle power gives the perfect speed for the hoe to prevent banging around at higher RPM.
   / Kubota L2900 Throttle Speed #3
You're doing just fine. The hand throttle is used a lot when tilling, mowing or doing other field work. You would set it to PTO speed and select the gear to go the proper speed. For chores with the FEL or backhoe, low hand throttle and using the foot is great.
(Technically, it's isn't a throttle as a diesel has no throttle.)
jb
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2015 Ford Escape AWD SUV (A50324)
2015 Ford Escape...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
1997 EZ S/A Spool Trailer (A49461)
1997 EZ S/A Spool...
2014 TROXELL KILL/TRANSPORT TRAILER (A50854)
2014 TROXELL...
